Remote control
Does anyone have any experience with remote controls for vista ultimate, to do away with the need to use a keyboard and mouse, basically I wanted to look at the options of converting a spare PC into a media server, but I don't need it to access the internet, it's really for storing my ripped cd's and dvd's.
Thanks in advance
Hiya. ÿJust setup and began using a Logitech Harmony 555 this morning. Use my MAC as a music server and it works just fine with Front Row so I'd assume that for Media purposes you'd be okay. But limited knowledge of Vista I'm afraid.
How does it pick up the signal then?, does it have a separate sensor to plug into your mac?
Sounds a cool piece of kit, so if I am correct, I would need to stick in an ide hdd and a hdmi lead to the tv and thats it?
Two concerns I have is 1) availability and 2) No flac support.
I did have a fleeting thought about using xp media centre...shudders, I guess technology still needs to catch up a bit, I did like the look of the JB7 Andrew wrote about, but again no flac support and as with the popcorn there would not be enough room on an internal drive for uncompressed storage of all my cd's...sigh.
Anyway thanks for the pointer frog it was an interesting read and it seems at least we are a step closer.
JCR1:Sounds a cool piece of kit, so if I am correct, I would need to stick in an ide hdd and a hdmi lead to the tv and thats it?
Just mail order from any european site... (I think my mate used a German one taht was in English)
Also , according to the www.popcornhour.com site...
popcorn hour website:
Audio codecs:
* WMA, WMA Pro
* AAC
* MP1, MP2, MP3
* LPCM
* FLAC
Excerpt from CNet review
If you're planning on using the A-100 for music, you should be aware that the audio codec support isn't as good as the video support. The usual suspects are here, including WMA, MP3, AAC (unprotected) and WAV. No OGG or FLAC support as yet, sadly.
JCR1:Excerpt from CNet review
Interesting. Perhaps they have released a firmware update for it.
Cant say I have tried it, as my mate uses it for video only.
From release notes, firmware Jan 2008
41. FLAC audio support added
- You will have to edit the following XML files in myiHome 4.7 and add FLAC extension
C😛rogram FilesmyiHomewebappsROOTxmlmusic.xml
C😛rogram FilesmyiHomewebappsROOTapplicationmusicxmlaudioext.xml
Ahh...right, looks like the cnet review is out of date...cheers froggie
JCR1:Ahh...right, looks like the cnet review is out of date...cheers froggie
No probs... looks like CNET didnt do their homework... Only reviewed a couple of weeks ago, and didnt pick this up...
