Question Rega TT platter height?
I don’t think it does. This assumption is based on my belief that all Rega tonearms have the same dimensions and mount directly to the Rega TT plinth. I may be wrong.
Different models have different thickness platters.
However, what I can't recall off the top of my head, is whether they sit on the sub platter sufficiently differently so as to make the platter height the same.
Unfortunately I am not home right now, so unable to check the dimensions of the Planar 1 and Planar 6
Reactions: ifor
Done that: "If you are looking at a new Rega arm then they specfic to each deck Rega sells. Are you wanting to use a Rega arm on another deck?".
