Rega P6 picks up radio signal and hum
babel
I've just bought a brand new Rega Planar 6 TT, fitted with an Audiotechnika VM750SH MM cart. It is plugged in directly into a Roksan Atessa via its built in phono preamp and connected to a pair of Dali Oberon 7. The main problem here is that it picks up RF signals--one of those Cristian stations (I mention this because they are famous for blasting their radio signal) and as a sonic bonus it also throws in a lovely hum. After some deep web research I've narrowed it down to:
- This just happens with the phono RCA inputs. The other analog and digital inputs are clean.
- All wires and intercoms unplugged (except obviously the P6), same problem...
- Speaker cables off and I still hear a hum and the radio aforementioned radio station through the headphone output.
- I disconnect the P6's RCA's and the problem goes away.
- I also tried unplugging the PSU... to no avail. That is not the problem.
- Out of sheer desperation I also tried the ol' trick of wrapping aluminum foil around the RCA cables. Nothing...
- Unplugged the router and wifi related appliances... Same.
- Took Bothe the P6 and the amplifier to a different room and listened through the headphones. Nothing...
- Tried with an old HK6300 Harman Kardon. Same problem
- Tried adding some ferrite braces to ALL the leads.... Nope...
- I live in the center of Madrid and I don't see any AM/FM antennas in the vicinity... but of course this is no proof there aren't any.
So I gather it comes form the turntable. Is it the RCA's, the cart, the tonearm, my electrical wiring distribution...? God knows... As most of you know, Rega fits the earth inside one of the RCA cables (I think it's the left one) so I can't "fiddle" with this option; the cables are also hard wired to the TT, so I can't try to replace them with better shielded ones.. Purchasing a phono preamp at this stage and risking it wouldn't solve the problem is a very discouraging option... There is no way to reach REGA tech service online or a proprietary forum to post or chat with a Rega technician
I'm desperate, since I can hear this "RF parasite" at a 30% volume and higher, so it spoils any vinyl I play. Tried everything above. About to throw the towel and stick to DIGITAL.
Anyone has any ideas that I haven't tried? It's really frustrating...
Thank you.
Din5
104
62
4,670
I would seek advice from a Rega dealer, I'm sure they will help even if you did not buy new/ or from them. You could also try the P6 with another amplifier ? just to test things further.
Gray
If you've got an earth connection on your mains supply there in Madrid Babel, you could try connecting the TT ground to that.
Make sure it is an earth before holding the bare end of a wire connected to it, to TT ground (preferably while the interference is occuring) to see if that kills it.
Try it to the outer contact of both RCA plugs.
Din5
104
62
4,670
Hi, have a look at this video, How To: Ground a Rega Turntable - YouTube
Play the video from 1.50 onwards, where it assumes that you don't have a Rega Phono ( which has a grounding post). If this is the case for your setup, then as the video explains, attach a short length of thin wire onto the outer RCA connection of the Left Channel RCA plug, and attach the other end of the wire to the ground terminal on your amplifier. I guess this should complete the grounding circuit between your Left RCA plug (which Rega uses as the ground ) and the actual ground within your amplifier..
Let us know if this works for you ?
Rega turntables don't have a separate earth wire, there is no way he can do that
Gray
I think it likely that the amp RCA socket grounds will already be electrically connected to its ground post.
But it's certainly worth a try 👍
No they don't have a separate ground wire.
But they do have a ground - and by connecting a wire from mains earth to outer RCA plug, he will be connecting TT ground to mains earth.
I wouldn't even attempt that on a European socket system.
They are grounded via the left neg cartridge signal cable to the amp or phono preamp so adding another earth isn't going to solve anything, in fact it could make it worse.
Buy a different turntable.
Gray
That's why I questioned whether he had a mains earth.
We've told others to connect TT grounds to mains earths before on here - no different.
Probably easy for him to return a brand new TT, but perhaps he may want to exhaust experiments first - unless he feels unsafe - or there is no mains earth in Madrid?? 👍
Of course, he shouldn't have to improvise.
But then he shouldn't have to be subjected to RFI.
Most European plugs don't have three pins. Its pretty easy to access the earth pin in a UK plug but not so easy over there.
Mostly on this forum I have been telling people how to get rid of unnecessary earths.... :)
Unfortunately the Rega method of earthing can cause more issues than it solves.
neozeo75
Same crap is happening on my system (with McIntosh MA12000). The hum reduces as the turntable (P6) is further away from the amp, but I cannot put it so far away because these attached cables are short. I cannot even replace the cables (truly idiotic design). Plus, as the turntable itself is picking up the hum, I am not sure how far out it should be from the amp. I am using a rack from SolidSteel, and I do not want to keep adding the stack to secure enough distance. It is not cheap. Well, I am ditching the turntable and won't be coming near to anything stupid Rega. Never again (and I hope others learn from this before throwing money out of the window).
DELBOY14
52
15
10,545
Thank you.
You could try an iFi DC blocker or ground loop eliminator on the amp, maybe both.
Oxfordian
If my little grey cell's memory chip is working correctly, somewhere in all the bumf I had with my Rega P3, Fono and Neo was a line that stated that due to possible interference the Fono should be sited as far from the P3 as reasonably practical.
Now I have my phono stage (now a Lehmann Black Cube) at the very bottom of the hifi rack the amp on the shelf above then the CDT and the P3 at the very top, I have no interference.
As a suggestion and before you throw the whole kit out of the window in frustration, is it worth looking at how you have the kit sited and is it feasible to add a new or pre-loved Fono into the mix to extend the distance between the TT and Amp?
