Came accross this article,found it very interesting,maybe someone else will
http://www.surroundassociates.com/spkrcal.html
duaplex said:Interesting read, I am going to increase my speakers to 85db and sub to 89db and see what happens. Through the Cambridge audio of course.
RobinKidderminster said:Another area where my knowledge is drained. I set levels to be the same using a meter. I then need to increase centre and tweak the sub. How does the level matter? 60db, 75db, 85db? How does it matter as long as they are equalised?
RobinKidderminster said:So can we ignore 'reference level' when balancing our home systems?
michael hoy said:I believe that most AV receivers disable the volume control when using the in built test tone and set this at 75dB, so it would not make a difference whether you set the dial at -50 or 0.
RobinKidderminster said:I think Michael you are 'agreeing' with me. I think my point is balance at any level is fine so why try to attain any specific reference level be it 75, 85 or 60? Cheers
Watching Dredd(again)this time with soundtrack thru the analogues is what got me into this mess... :rofl: man that is one kiss-ass sountrackduaplex said:Indeed, I am going through this right now and was about to post something similar. I generally listen at around -20 to -15 DB and balance my speakers accordingly. If you are using -20 as a starting point then reaching 85db is impossible on some devices, like I found last night on the 751db. You will have to go up to about -10 on the listening level and then tune it to 85db, which I did and it was booming as GSB found out too.
-15DB tuned to 75db, with the sub on 85db words well for me. Untill you watch something like Dredd that loves its Bass. :O
