RED FLASHING ANNOYING DOTS
umbucker
133
I have a 42" Hitachi Plasma screen using a Denon AV receiver. I seem to getting scattered red dots flashing on my screen which are visable on dark scenes. I thought at first it could be my amp but I have plugged both my Blue ray and Sky HD direct to the TV and the problem continues. Does anyone know what this could be ??
Are they visible on a blank screen - ie on an input with nothing connected? If so, may be a panel/processor problem; if not, more likely to be a problem with one input, or a signal problem.
Hi umbucker:
Sorry but i might have some bad news for you - i had the exact same issue with a 50" Philips plasma about 3-4 years ago - the red dots or how I like to put it the "red dot crawl" on mine started out when you first turned the tv on and then went away after about 10 minutes - then they stayed on longer until they wouldn't go away - I took in into a Philips repair shop and they tried a couple of new boards but in the end it was a defective plasma panel. Fortunately it was still under warranty and Philips replaced it with a 52" LCD which to be honest I like even better - the black levels are not quite as good but everything else is way better.
Wazy
