Recommendations Please
I just realised that the cable upgrade i had in mind would be too bulky to fit neatly under the rug.
So i need some pointers as to some good quality 'flat' speaker cable for my surrounds.
Thanks.
daveh75
826
231
19,270
imo depends what your using on the fronts, i think you should at least stick to the same manufacturer of cable if you cant use the same type front and rear
