Rear Speaker Choice - Advice please
Hi All,
I've been lurking in the forums for a while now and found them really helpful. Hopefully, you'll all be able to give me some sound advice.
I have just upgraded my stereo and I now have a Marantz SR4200 AV receiver (which I hope to upgrade to the Sony 2400ES shortly), connected to a Linn Centrik centre speaker, with preouts to an Exposure XX amplifier and Linn Keilidh fronts. I'm looking to add some small wall mountable rear speakers to this set up that are suitable for a small terraced house (one will be mounted above a door).
With a budget of not more than 250, I'm considering a pair of B&W M1's. Can anyone offer any opinions on this choice and/or make any other suitable suggestions?
Much appreciated,
James
jpm5555:
Hi All,
Much appreciated,
James
The Monitor Audio Radius HD speakers (not sure of their correct name). I have the Radius R90s that the new ones replaced - very good speakers. They come with their own wall brackets. What's your subwoofer?
I don't have a sub currently; I'm not sure the neighbours would appreciate it! I find the Keilidh's are capable of outputting more than enough bass tbh.
Thanks for the quick reply - I'll check them out.
