Quick help
Hi i need fast response what i should buy
tv needs to handle well sd content
will be used to play video games and occasionally as a pc monitor but only for gaming
good hd picture quality
i do not need any super extra features on it because i will stream films from either pc or ps3
Here's my list
panasonic txp46g10 bit old but i heard still very good (about 600 quid)
samsung le46c580 only 50 hz is that a problem? (600 )
samsung ps50c580 (760 )
samsung ps50c6500 (830 )
samsung ps50b850 read this is very loud set is that true? (800 )
i beg for quick help and maybe somebody has some suggestions?
If you can stretch to 800 quid i would go for the46g20 panasonic plasma better than the one you mentioned and they have removed the annoying 2 plane of glass so no double image from side view and I speak from experience with LCDS i have had sony(still do) samsung LG and phillips and have never been happy with any of them so i will get a panasonic plasma next time for sure much better for gaming mainly due to low response times on screen response and input lag!!
i checked and 46g20 is over 1000 pounds or maybe you know a place to get it cheaper?
