I heard you can use the Oppo HA-2 as either a DAC or a DAC and amp, but which port is what? Do you use the DAC through the micro USB port, and the DAC and amp through the audio-in / line-out jack?
davedotco said:It can do all these things, it sounds complicated but when you have hands on the unit it really is pretty simple.
There are 3 inputs, for an iPod/iPad using a regular type A usb socket, an asyncronous micro usb type B input for use with a computer and a 3.5mm analogue line input.
With either digital input used the HA2 produces a headphone output with volume control and a line out at a fixed level of 1 volt, these operate simultaneously. The analogue input drives the headphone amp only, as it uses the same connector as the line output, no line out is available, it would be pointless anyway.
I use one primarily to listen from my Macbook, I use the supplied cable which also keeps the battery topped up. It is a delightful unit.
Tacanacy said:davedotco said:It can do all these things, it sounds complicated but when you have hands on the unit it really is pretty simple.
I didn't understand that. I just want to know which port is the DAC and which is the DAC-amp. I assume you use the micro USB (and USB-A) as a DAC, and the audio-in / line-out jack as a DAC-amp...
Tacanacy said:Not according to this: https://www.youtube.com/watch?v=68GJxiBSLOg
So if it's DAC-amp either way, what's the difference between using the micro USB and audio-in / line-out jack with a smartphone and a PC (I don't use iDevices)?
