After reading the DAC test in the September edition, which seems a very good test, the 'verdict' for the Rega it says: "Got the budget? Got the system? Hear the Rega".
Really trying to clarify what system (or brands) you wouldn't use the Rega with. Are you talking about entry-level Cambridge or Marantz, for example? Would the Rega, in your view, be an overkill?
