MUSICRAFT
CnoEvil said:and should have included Hegel.
Hi Cno
I forgive you *biggrin*
All the best
Rick @ Musicraft
ThijsJ said:Hi Musicraft,
do you have by any change (positive) experience with the Rotel RB-1582 MkII power amp in combination with the SCM19 passive loudspeakers (latest version)?
ThijsJ said:Thank you again for your input MUSICRAFT, as an expert your experience is very helpful.
I have 2 questions:
I checked the manual of the Hegel H160. It doesn't say if the music stream by Apple AirPlay is digital or analog (after iPhone own Dac). I'm wrong if I think its (only) analog (made for ("receivers" to connect to) active loudspeakers / amplifier and loudspeakers)?
Do you have positive experience with Naim amplifiers as well (in combination with ATC (SCM19))? For example the XS2? A Naim amplifier had always my preference before I bought the ATC SCM19 but I'm not sure its a good match and if I should list it on my short list. What is your experience?
ThijsJ said:Good to know damping factor isn't important for sealed loudspeakers.
ThijsJ said:Thank you MUSICRAFT for all your answers / information, your input was very useful and appreciated. It was a great help.
ThijsJ said:Thank you again for your input MUSICCRAFT, then I will use an active pre amp for my listen / choice session and together with the Rotel power amp not more expensive then the integrated Naim.
