Qobuz connect
jamesrfisher
190
163
18,770
I have just updated my app and now have Qobuz connect. They say it's a trial. Unfortunately it doesn't work with either my Primare amp or Bluesound Node.
Is anyone else trialing it and if so how is it?
Since it's new manufacturers will have to update their firmware to be compatible if possible. For example Heos become Tidal Connect compatible only in the last year.
Check your manufacturer website for more information be it Primare etc
I quit Qobuz recently as no connection feature and TIDAL had become cheaper.
I like TIDAL but I can’t stand no new releases on tha APP so I still use Qobuz app to discern new releases on a Friday !
Unfortunately, despite a recent firmware update, my Yamaha R-N800 is not compatible with Qobuz connect I called Yamaha and they didn't seem to know anything about when or if they will be making it available as a feature in the future. I updated both the desktop and iOS Qobuz apps but nothing shows up. The customer service guy at Yamaha said he would pass it on to the development team as a suggestion.
As I said, it will be up to the manufacturers to enable it if possible, as sometimes a hardware change will be necessary - meaning you'd have to wait for a new model.
As you said... yes...
I was simply providing some feedback as requested by jamesrfisher re: the situation with Yamaha products. If enough people call in and request it Yamaha may come out with a firmware update with no need to buy new gear. They have it implemented already in some of their products.
Have they implemented it in some of their products? It may be in older products, irrespective of brand, it may not be possible as new hardware will be required.
I know theres complaints on blue sounds face book pages about it not being available yet, and the chatter is that it will be months.
Do you think they'll ever do it, they've never done so with Amazon Connect and they've had years to.
Amazon Connect does not exist
If they can do it in firmware I'm sure they will. But sometimes a hardware change will be needed. HEOS is now Qobuz Connect ready across several Denon and Marantz players, but not all.
That's kind of picking holes when it's completely uncalled for isn't it??
You can cast from you phone / tablet to various devices like WiiM's or Echo's in the same way as you can with Spotify Connect and Tidal Connect .... so what specific name would you like to give the Amazon version to keep you happy?
I haven't time to go through the thread, but I don't believe Primare are able to accommodate Qobuz Connect. I'm sure Bluesound will have it in time as they're usually pretty quick on stuff.
Ah apologies.
Hi
Spoke to Primare and they won't be supporting it, neither do they support Tidal Connect.
Bluesound have said it's something they will do in future. Has caused a lot of debate on their community forums.
Reactions: jjbomber
