QED Revelation - Bi-wire or not
I have tried QED Revelation in my sytem of spendor s3e, creek evo amp and arcam cd192 and it sounded great.
My question is, will I really get £60 worth of benefit if I bi-wire, or do I stick to single wire and use the same cable for the jumper links?
If I save the £60, then I can get alot more vodka, and get nailed listening to my music instead!
Phil
Although the usual rule of try it and see applies, personally I would stick with single wire and pocket the rest of the cash.
Only cos your SA1s have only one set of terminals, Ig
very true, the SA1's are single terminals....
I would try it, but my local shop doesn't stock it, and he won't get it in.
I might just buy vodka, then I won't notice the difference!
Unless you have a pre and power combo, bi-wiring doesn't really bring about much improvements, IMO.
I would suggest you stick with a single wire and use jumper links instead.
JohnDuncan:Only cos your SA1s have only one set of terminals, Ig
There's a reason for that...[sprints off]
