QED aerial cables - worth it?
roger06
374
Hi
I want to make the most of my new Pana plasma - and I've also moved my kit away from the telly so need a 1m aerial cable from the wall to the DVD recorder, a 5m from the recorder to the TV and a 1m one for the tuner to plug into the wall.
If I buy the QED QUNEX cables I'll be spending around £130 which hurts. So can anyone tell me if it's worth it over the cheaper QED performance range which would be more like £50 for the three...
i really wouldn't bother when it come to aerial leads, since the cable from your aerial to the wall plate wont be cable to that spec i really dont think the last few metres will make a difference. just buy some well made reasonably cheap cables and you should be fine
http://www.audiovisualonline.co.uk/dynamic/eshop_products.set/ref/2423/ixos-quad-shield-custom-length-aerial-interconnects/display.html
I bought the above - can't fault the cable or the service from Audiovisual
Thanks guys - great advice! I've placed an order with AudioVisual online and with the saved money also bought a component video cable to replace a s-video / scart ...
cheers
