PV1 problems
My PV1 all of the sudden doesn't sound right. It sounds boomy if that's the right word. It draws attention to itself which is something that never happened before. I run Yamaha's auto setup again, i check the settings on the woofer but no difference. It's not as sharp as before, not as fast. Anyone any ideas what's the problem and what caused it? Is it me just imagining things? It's 8 months since I bought it. What should I do?
Take it back to where you got it and ask them to check it for you.
Take a disc that it's clear to you where the noise sounds different and point it out to the assistant.
See if they notice anything.
Cheers,
Cofnchtr.
