- Aug 10, 2019
- 2,556
- 5
- 0
Hey all sorry not sure where to post this🙂
Just installed a 500GB HDD (WD) to my PS3 my previous one was the one it came with which was 80GB(seagate)
now on the system info screen before upgrade i had 10GB of 74GB available with the 500Gb HDD i have 358GB of 465GB available now i did have issues installing the software on the HDD as the PS3 could not format it as it said it needed the latest update 3.15 it took my thick head a few attempts to realise i needed to get this from sony and put it in a update folder on a mem stick. My restore file i.e my data is 54.3GB.
I am thinking that the HDD has not been formatted correctly or as it is a bigger drive the software installed by the ps3 is less compressed? i will try to format it again via the PS3 then buy a dock for the HDD so i can see what my laptop makes of it!
I would of course like to be able to use all of the data available and 43Gb is a lot of memory so any input will be much appreciated🙂
many thanks
many thanks
