- Apr 3, 2008
- 21
- 0
- 0
Hi all
Ive been running the Ps3 on the samsung UE40B7020. Is there a setting that needs to be adjusted to enable 100hz? When a BluRay is run, the settings at the top left pop up with 1080p/60hz?
Does anyone know how this is due - to the TV being an 100hz TV? ProfessorHat youre hot on the Ps3 settings.
If it helps, Its via a HDMi Platinum cable: http://www.hdcable.co.uk/hdmi-cable-platinum.html
Thanks in advance
Thanks in advance
