Gel Well-known member Apr 17, 2024 1,538 581 2,570 Jun 9, 2025 #1 https://www.amazon.fr/dp/B0DDZ6P92X?smid=A1X6FK5RDHNB96&th=1 Will it work in the England? Thanks
bigboss Moderator Mar 25, 2009 6,444 1,387 27,570 Jun 9, 2025 #2 Yes it will work, you'll need an adapter. Not sure about the guarantee though. Reactions: Gel
Gel Well-known member Apr 17, 2024 1,538 581 2,570 Jun 9, 2025 #3 bigboss said: Yes it will work, you'll need an adapter. Not sure about the guarantee though. Click to expand... Thanks! It was a good price then.
Gel Well-known member Apr 17, 2024 1,538 581 2,570 Jun 12, 2025 #4 If you have bought an ARC or an Ultra Arc this would be a good match for a good price: Refurbished Sub Mini: The Compact Subwoofer with Big Bass | Sonos Add remarkable depth to your home cinema by pairing Sub Mini with Beam, Ray, One, or One SL. Get bold bass in a compact frame with Sonos Sub Mini. www.sonos.com
