Andrewjvt said:
Ok thanks for all the info.
Question If I don't have a blackened out specific room available Would it almost as good if I only use it at night when it's totally dark? More info on this would help.
Hi Andrew it doesnt work like that - when you install a projector screen you install a massive light reflector and in some cases amplifier.
You shine even a phone screen at it and see how much ambient light there is in the room, that reflected ambient light bounces off the screen reflects off all the walls and back onto the screen washing out the image - reducing contrast basically.
Now amplifiy the phone screen light to an insane bright bulb and the issue becomes a serious reality.
In a light room you will want a light rejecting screen - these work by reflecting parts of the light in a different plain so not straight back out and help to improve contrast.
If you want a great demonstration watch videos on Screen Innovations Black Diamond - they show the issue perfectly.
Now no such thing as a free lunch - first issue with light rejecting is the image wont be as bright - now brightness in a projector image is really important as it helps with image sharpness.
2 screens from the same company one will have a sharper brighter and more LCD like image, the other a softer more plasma like image, but it wont be as punchy and crisp just by how they reflect light. This is referred to as gain but there is also more to it - I think more so with AT Screens, like anything some are better than others.
You will want a brighter projector with a light rejecting screen ideally, not normally an issue with modern light cannons but worth pointing out as higher brightness means more fan noise for example
The other issue with light rejecting screens, a bigger one they didnt use to make them Acoustically Transparent - otherwise I would have bought one.
They might do now days but it wont be cheap
