Hi All,
I'm still quite new to the world of vinyl so apologies for anything silly I may say in the below!
I've recently bought a Project Genie 3, and have it hooked up to my hi-fi via a preamp. However, I am having problems with records skipping and looping the same split second of music. Strangely this doesn't happen on all records, and on the records it does happen on, it seems to do it at certain parts of the song. I've tried adjusting the arm weight which has helped the problem slightly, but I'm not sure how safe it is having the weight so much higher than it's supposed to be.
Basically, I'm at a bit of a loss as to what else to do to fix the problem, which I'm sure shouldn't be happening as the MK3 is apparently a pretty good bit of kit. I don't think it's a problem with my records as most of them are new. I've read it could be a problem with vibrations causing the needle to jolt about in which case, what would be the best way to fix that?
Any other ideas would be greatly appreciated as i'm at a bit of a loss!
