- Aug 10, 2019
- 2,556
- 5
- 0
I bought a Project Debut turntable off Ebay at the start of the year. It came with an AC/AC 16v/500mA power adaptor/transformer that connects via a small plug at the back.
I have broken the plastic earth pin on the adaptor so need a replacement. The only ones I can find available are for laptops. I checked the instruction manual and it says that the turntable comes with a fixed power cable. As it's second hand I can't tell if this has been modified or if the adaptor came with the turntable contrary to the manual. Does anyone have one? and does it have a fixed power cable?
I would prefer to replace the adaptor with a fixed cable if this is possible.
