Project Debut Replacement lid
dx052
30
Where do I buy these from? My current one is covered by some brown tape which I applied when I was moving and cant the stuff off now. Thanks
if you contact the uk distributor theyll either supply with you one or tell you where to get them
your local project dealer should be able to help as well
dx052
30
I didnt think of Lighter fluid. I have already gone down the road of giving the Lid a warm bath to loosen off the tape hopefully & some how clean the gum of. (Get yourself a Seat or Skoda there cheaper to run)
John Duncan
dx052:I didnt think of Lighter fluid. I have already gone down the road of giving the Lid a warm bath to loosen off the tape hopefully & some how clean the gum of. (Get yourself a Seat or Skoda there cheaper to run)
But use the same bosch parts. I have become adept at finding refurbed parts off the 'bay...
Anyhoo, try the lighter fluid, is very good at getting adhesives off.
dx052
30
Okay I,ll try that. I,ll take the lid out of the bath and dry it off then : ) I will also have a look at Ebay whilst I am at it.
Henley
dx052:
Hi There
I found a supplier now, didnt think they would be so expensive though.
The lid should cost around £20.00.. With respect, I'd hardly call it expensive.
dx052
30
Hi, The one I found although I didn,t look to far was £45 which I thought was a tad expensive for a dust cover thats all. For future reference were can I can I get it for £20.00. Thanks
margetti
134
dx052:Hi, The one I found although I didn,t look to far was £45 which I thought was a tad expensive for a dust cover thats all. For future reference were can I can I get it for £20.00. Thanks
Considering I paid £40 for a debut on fleabay, yes £45 is ridiculous...
Henley
Our website or any of our dealers
margetti
134
chebby:margetti:
Think of those 'poor' Linn Sondek owners wanting a lid. (£139)
Now THAT really is ridiculous! I mean, really, how can that price possibly be justified for a piece of plastic... the economic laws of supply and demand have a lot to answer for sometimes...
Thank you for sharing this valuable information. Right now I'm busy with my project and then I'm planning to go to Canada . That's why these days I'm too busy with my documents and can not afford to search for these same things. Keep sharing.
