I've just recently purchased this amp and although it's fantastic it does have it's Gremlins..
I'd been reading on the internet about problems with this amp, freezing issues, not turning off properly and having to unplug it from the wall, reset it etc etc
And it now looks like it's started to play up with me
First of all when I switch it off via both remote or the front panel, it "clicks" as normal but the actual display takes forever to switch off :O
And earlier when I switched it on to watch sky , the sound for sky came on for about 5 seconds then "just" the sound switched off!!
I tried a bluray disc and the same there- no sound! So I had to unplug at the wall (just like you do a sky box) then plug back in again, it came back on and the sound did too, but now when i select an input from the remote i.e say from sky to bluray it makes a clicking sound that wasn't there before, it's very annoying to say the least.
I hope it's not going to be like a sky box where I have to unplug everytime if something goes wrong.
Anybody else had any issues like this with this amp?? If so, what's the solution? And the firmware is all up to date.
