Question Presets on Audio Pro Addon C5/C10
Daniel_R
Hi there,
I am interested in buying an Audio Pro Addon C5/C10. I would like to ask a question to all the owners of these models:
After adding a preset (ex TuneIn internet radio) will I be able to access it without having connected a smartphone via Bluetooth/WiFi? In other words will I be able to power on, select my preseted internet radio station using one of the 4 buttons and listen even without having a connected device (laptop, android phone etc) at the moment?
Thank you in advance, as this is a feature I would really need.
I'd guess yes to that Daniel, based on the reasoning that that's what the presets would be for.
But don't take my word for it.
If you enter the model on Richer Sounds website, you can download a pdf of the user manual - which is bound to tell you.
That's how it's supposed to work once connected to WiFi and setup.
Have a look at the C5A which has alexa built in then can just use your voice for ease, for example they don't come with a remote to change volume etc so would need to use app on phone or controls on top with c5a just ask alexa
