you'll have to try it and see.
A DAC should output a line level analogue signal that can then be amplified, yours is a bit more than a straight DAC so this procedure sets up a fixed line level output from your device......But if I understand correctly this doesnt really bypass the preamp does it?
A DAC is not a DAC without some "amplification" or else how would it be able to transfer sound?
I seriously need some HiFi education
Unfortunately there are a great number within your budget.....can you get to audition any?I see thank you very much.....and this is why I am now in a need for the real one. Straight DAC.
Requirements:
1. Should match with Preamp ATC CA2....so rca out on the DAC.
2. Remote just to turn it on and off
3. Price..... around 4500 dollars
4. No Chi-fi
For some reason I just don´t want anything that reminds me of a turd in the name, if you know what I mean 🙂
The one I found so far:
Benchmark DAC3
Yes... The ones I saw with remote controls seem to be DAC/headphone amplifiersyes my dealer will look if he can order then he will for me 🙂
Vany= many?
Bel Canto or Mytek Brooklyn DAC+ might be worth looking into, I know they tend to come with remote controls
It's £2389 and still has headphone amp and volume controlPureDAC | High End Audio Components - B.M.C. Audio
PureDAC An advanced DAC? More exactly, a balanced DAC with reference level headphone and pre-amplifer.bmc-audio.com
I think I am going off topic. Someone maybe changed my mind on preamp or not to preampIt's £2389 and still has headphone amp and volume control
I have no idea where you are going.Well. Either way I will update my experience with CA2 + 40A.
it is so easy to get confused.
people are saying not to preamp etc.
But then why are musician using a DI box before the input…approved to be better(my own ears)
This should not sound better according to the non-preampers
I only got this CA2 because I wanted better sound. Only for preamping the rme 🙂I have no idea where you are going.
There is only so much you can plug directly into those speakers, if you need to add other peripherals you need a preamp or some sort of source selector.
an expensive way to go about things. Hope it makes a difference.I only got this CA2 because I wanted better sound. Only for preamping the rme 🙂
Preamping the RME with a CA2 is a pointless expense, unless you are need to use it as a volume control for other analogue sources. You will not get "better sound". RME can and works great connected straight into active speakers.
ADI-2 DAC fs & Active speakers (Page 1) — ADI-2 & 2/4 Pro series, ADI-2 DAC series — RME User Forum
ADI-2 DAC fs & Active speakers (Page 1) — ADI-2 & 2/4 Pro series, ADI-2 DAC series — RME User Forum —forum.rme-audio.de
www.audiosciencereview.com
