fujineg:
Just bought the case from HMV for £15 and downloaded the free app, I'm very impressed, I have added my Blu ray player, Amp, and TV so far, all works perfect. Will be fab once I've programmed all my kit.
Once complete if it all works well, will save me nearly £300 on the Logitech Harmony 1100!
Any one else got this gadget?
Jon
Jon,
After many years of excellent service, my harmony 895 has been dropped a couple of times and the buttons are now difficult to press, I have been looking for a replacement, that I can use with my iphone, the redeye is the front runer at the moment.
But at £40 or if you can pick it up for £15, this would be a steel, however, can you answer the following:
Can you create a device with multiple sources, i.e. I run my amp to handle sound, and Sky HD to change channel, so switching between the two would be a pain, but if i could customise the buttons, so I can turn over the channels on sky, but turn the volume up / down on my amp, then this would be an option.
Any input would be appreciated.
