If you click on your name (top right hand corner of the page) it should pop up a box.How do I post Avatars on this new forum?
You should be able to click on your (empty) avatar picture and a box allowing you to browse for an avatar picture (jpeg, jfif, bmp, png, etc.) on your PC should pop up
- Browse and select a suitable picture
- Click "Okay" when finished.
Glad to be able to help - see you're all sorted nowMany thanks!
