I want to replace my Denon AVR-1707 with a something with hard wired AirPlay. It needs to be as good as the outgoing, but doesn't need to be any better. Recommendations please.
Apple TVs work on AirPlay on Ethernet. It automatically switches WiFi off. I assume it's the same with other AirPlay devices.bigboss said:I'm not aware of AirPlay working over Ethernet. I always thought that AirPlay was designed to "play through the air", I.e., wirelessly. Check this: https://discussions.apple.com/thread/4018172?start=0&tstart=0
Yes, those are they, but a have a Dali sub with them. I will try to get a home loan before purchasing. We are only small time movies watchers and this isn't for the HiFi room; it's for a second sitting room that doubles as a movie room with projector and screen.bigboss said:By Kef 3000, do you mean this one?
http://www.sevenoakssoundandvision.co.uk/p/kef-kht3005seav-speaker-package?gclid=CKev18n98bUCFfLLtAoduzUAqQ If yes, going for the 2313 or 2113 will bring significant improvements over the 1713. The difference is not only about 5.1 vs 7.1. Tonally, they're better sounding. Make sure you demo before purchase.
