Hi - Im sure this is quite a simple process and I am just making it complicated but I am hoping someone can offer me step by step advice..... I am wanting to connect a external Stereo Amp (Rokason k3) to my Denon AVR 6400H AVR, so that I have a better system for music while keeping surround capabilities.
I understand that I need to wire the new amp via the Pre-outs of my AVR and into the Vide (HT bypass) inputs of the stereo amp
Where I am very confused is how I assign this in the menu of the AVR. I have tested this with 2 external speakers and the result was that the 2 powered spears worked fine, but the L & R speakers still wired to the AVR were being powered at the same time!
So there must be a setting somewhere to 'shut down' the 2 channel amps in the AVR? but I cannot seem to find this anywhere, and there is no mention of it in the manual.
My worry is I unplug the speakers from the AVR and wire to the new amp but power is still being sent to the 2 channels within the AVR which will cause damage to the AVR.
I should add that my current set up is 5.1, so the AVR will only actually end up powering my Centre and Surround channels until I upgrade to atmos.
Thanks for any help you might be able to offer
