- Aug 10, 2019
- 2,556
- 5
- 0
Hi guys, I was watching the Dark Knight yesterday and found out using the "Select Button" on the PS3 remote that the videa data was being streamed at roughly over 20MBS.
However the Audio was being streamed at 48Khz at a constant 448kbps (Dolby Digital). After using the menu and changing the Audio to Option "2" - The Audio then was streaming at 48Khz at a rough average of 1.6Mbps. (This is most likely DTS?) I was unable to get the Dolby True HD Signal, which the disc can stream and my amplifier the Denon-4308 to work in sync. Other blu ray discs I tried presented the same problems.
I checked the settings in the Audio section of the PS3 which were set to automatic and all the formats were checked. I then tried to manually set the Audio options in the PS3 to just Linear PCM signals. Again nothing over 1.6Mbps Audio streaming. (All my information about the Mbps is from this months Blu Ray section within the magazine, trying to get the sound sorted 🙂 )
Cable from my PS3 to the Denon is the Chord HDMI Silver Plus 1.3 & Also has the latest firmware updates on the unit. The Denon automatically sets itself to "MULTI CH IN" to recognise the PCM signal being sent to it
Any ideas? Thx
Any ideas? Thx
