Having just bought a Panasonic 58V10 that is currently on an Alphason 105 stand in the corner, I am trying to find a wall bracket that also incorporates two shelves underneath - one for Sky HD Box and Sony BDP550 Blu Ray player and the other for Yamaha YSP 1000 Sound Bar. I saw a corner unit in Comet where the braket attached to the walls and the shelves hung suspended underneath - the AVF Corner Unit. Unfortunately the corners I have will not take size wise a big Plasma so I am looking for a wall bracket with shelves underneath the lower shelf being able to taker the sound bar at 1.050m length. I have no objection to the unit going down to the floor with a stand provided the Plasma is right against the wall. The only one to the floor I have found which will fit a sound bar - but not big enough for a 58V10 - is the Alphason ARB 1100/2. I see from the AVF site thay do do shelves with cable hide runs but the shelves are not long enough for the sound bar
I have looked at most net suppliers but can find very little like the Comet corner unit suitable for a flat wall with reasonable sized shelves. Any advice or pointers in the right direction would be appreciated.
Thanks in advance
Brook
Thanks in advance
Brook
