pioneer vsx lx 60 andya
Hi Andy. Got my vsx lx60 yesterday, bit of a beast to set up but i got there in the end. sounds really good. Ive connected my pana bd 30 via hdmi cable,what should be displayed when playing dolby true on the lx60? many thanks. Paul.
It decodes Dolby TrueHD, so it should display this as long as you're using a HDMI 1.3 certified cable and you have the BD30 set to output audio via the HDMI as bitstream.
Hi professorhat. I have the bd30 connected with hdmi lead and set to bitstream but the lx60 just displays the word digital! any ideas? thanks. paul.
hi paul
yes this is one issue i also have ! in the maual it says if recieving dolby true hd the reciever should display the little dolby sign and hd at the side of it. but mine only displays the little dolby sign and digital at the side of it.(as if it were recieving dolby digital 5.1) i am phoning pioneer today so will let you know what they say.
also when recieving dts ma the reciever will display dts ! i personally think it should display dts ma or how are you sure its recieving the correct decoding.
they should have set up the reciever to display the different audio codes or how are we supposed to know its working correctly. but it does soung good though.
watched day after tommorow last night with dts ma (i think) the sound is incredible !
andy
Hi Andy. I thought i was doing something wrong. I agree the reciever should display all formats. I am also going to contact my supplier tomorrow. Will let you know if i find anything out. I purchased led zep song remains the same on blu-ray this morning, looks & sounds pretty good. If you want to e-mail me direct my address is paul.bettridge@homecall.co.uk contact you later. Paul.
hi paul
phoned pioneer today but were shut due to bank holiday, will phone again tom.
it's quite annoying that a great reciever like this lets its self down by not displaying the different audio codes (unless were doing something wrong) im sure it would have been a simple thing to have it displaying all the codes. lets hope pioneer sort it for us or they will get a roasting from me.
get back to you tom, andy.
ps, have looked at the zep dvd myself but not bought it yet, is it worth it. i have whitesnake on standard dvd and that looks and sounds great.
Hi Andy. Thanks for the reply. The led zep blu-ray is worth getting, they have done a good job on both the sound & picture. I also have the whitesnake dvd which is pretty good. Another one that has a good soundtrack is the eagles farewell tour. lets hope tomorrow gets us the answer to our display problem. Paul.
hi paul
forgot to take pioneer number to work today so phoned when i got in at 5.45 but shey shut at 5.30 ahhhhhhhhh
have put number in my wallet for tom so will defo phone and see what they say.
yes the eagles another excellent band. might have a look at that one cheers, andy.
Hi Andy. Its not the lx60 at fault its the settings on the pana bd30. Im not exactly sure what i did now, but if you go into the settings on the pana and go into easy settings then select default settings then carry on to picture and sound settings and make the relevent adjustments it should work. in the audio quality section the output should be set to bitstream and the secondary audio set to off and the same settings in the user menu. it worked for me. i now have DDTrueHD displayed on the main display. Hope it works for you, good luck Paul.
hi paul
tried the new settings you gave me and it works fantasticcccccccccccccccccccccccccccccccccccccccccc
now also have dd true hd on the display, thank you very much, sounds emense. im so glad you bought one, and that i reccomended you buy one, which in turn has helped me.
cheers again paul have fun with your new toy. by the way what surround sound system are you using.
andy.
Hi Andy. Im pleased my settings worked for you, great sound eh. You may find my speaker choice a bit strange! front main-pioneer HPM150. center-Kef Q6c. sub-mordaunt short ms308.surround-mordaunt short avant 900i.rear surround-wharfedale diamond 8.1se. keep in touch & thanks again for everything. Paul.
