- Aug 10, 2019
- 2,556
- 5
- 0
i bought a PIONEER PDP-4270XD plasma tv about months ago and am really disappointed with it. i used to own a regular CTR LOEWE PLANUS and the picture quality of it way surpasses the supposedly superior plasma. firstly the colours on the plasma are really artificually bright - yes, i have tried adjusting all the relevant controls and reducing the brightness etc - there's just something 'untrue' about them, a bit like when you brighten a digital photograph in photoshop. about a month ago i switched it on and the picture had gone very dark. comet sent round an 'engineer' who basically turned up the contrast to +45 (not sure where it was set before - it's the only control parameter which doesn't have a + or - but starts from 0) and the brightness to +10 then and claimed that these tv's occasionally re-set themsleves to factory settings... which sounds unlikely unless the people at pioneer like their tv screens unwatchably dark. i did write to pioneer for their advice over this fault and received no reply....hmmmm. the biggest problem i have had with it though however is picture shudder or trails left by images. this is particularly noticable on skintones where dramatic lighting is used i.e. one side of a face is very brightly lit and the other almost in darkness. the darker side leaves a strange trailing effect almost as if the screen simply cannot cope with the subtle nuances of the changing light. it's headache-inducingly bad (quite literally). the worst example i've come across so far is when watching 'the illusionist' with ed norton and paul giamatti - due to the way it was lit and shot large parts of it were basically completely unwatchable due to the problems described above. i should add that my cables, whilst not being of the stupidly expensive variety are of reasonable quality and, having worked in the music recording industry for over 25 years, i know how much twaddle is written about posh cables... suffice to say i'm 99% sure that the're not the problem here. my dvd player is also a decent one. anyone any thoughts please?
