Pioneer BDP LX71 - Region 1 Help
I have the LX71 blu ray player and want to be able to play my hoard of region 1 dvds. Any ideas if there is a unlock available otherewise I feel a little cheated?
no handset hack that I know of, I have seen a company that can make it multiregional for dvd online cant remember the name but a google serch should bring it up. You will need to send it off and dont for get that any pionner warranty will be voild.
ElectroMan
30
LeeMason:I have the LX71 blu ray player and want to be able to play my hoard of region 1 dvds. Any ideas if there is a unlock available otherewise I feel a little cheated?
Did you check when you bought it? I don't think you can feel cheated by Pioneer, as they only supply it as region 2.
You could look here - but it will entail sending your player to them to be modified. You should also ask if any future firmware update from Pioneer is likely to invalid the hack.
I recently bought the LX-08 from Sevenoaks (Chelsea branch) and they multi-regioned it for me when I picked it up. Given that they are setup as franchises I'm sure they would be more than happy to do the same for you (though it may cost a little). It took about 10minutes to put the latest firmware and multi-region the unit. I don't know if you have one near you, but the guys in Chelsea are excellent if that's close by.
