Pioneer 4280 XD Input problems with Sky HD - Please help?!
I've had my Pioneer for just shy of a year now (thankfully within its warranty) and am concerned it is starting to fail on me.
Yesterday I started having problems when watching Sky HD in Input3, in that the screen would go blank (black, with thin green lines) every 15 mins or so and would then return to the recording. It also happens when simply pressing "tv guide" on the Sky remote - goes blank and then goes to the menu. This is v frustrating.
I've changed the input, swapped HDMI leads and checked if the problem occurs on my Sony next door. Nothing has helped, although the same problem does not happen on my Sony next door.
Each time it happens, it's as if the Pioneer is receiving a new signal and resets - the top hand corner shows "Input 3, Auto, Wide".
Please may you let me know what might be the problem?
Thanks!
