Hi all my system
Technics 1210 with a rega rb250 arm Litz tone arm cable to black rhodium interconnects ortofon super om20 cart and fully origin live upgraded also has a timestep power supply. Then in to my Cyrus pre xpd onto my Cyrus 8 power's and there all psx-r. My speakers are monitor audio rs6 and the phono stage I'm using is a rega A2D but I can't help thinking my phono stage is limited and holding my turntable back what do you guys and gals recommend thanks for looking Steve
Steve Porter said:
Hi all my system
A possible cartridge upgrade?
Depends on your budget really.
chris_bates1974
96
37
10,570
I auditioned the A2D and the Fono MkII at the same time. The difference was night and day. To my mind the Fono is an absolute steal at a double espresso under 200 quid.... I'd recommend listening to one.
Auditoned with higher spec Cyrus amp than mine, and KEF R500.
