- Aug 10, 2019
- 2,556
- 5
- 0
After some searching, i've narrowed my choice down to the two listed. I would like a 40 or 42" screen, 1080p HD, 100Hz TV and I have no more than £700 max to spend.
I'll be using it in my front room, with an Xbox 360 and for SD pictures at first, with a view to upgrade to a Blu Ray player and HDTV in the soon-ish future.
I think the two I've picked out are pretty good choices, although i'm concerned that the Sony appears to have pretty bad clouding problems on about 50% of everyone who buys one. I've only heard good things about the Phillips so far.
Does anyone who owns either, or looked at both have some advice. It's a lot of cash for me, so I want to make sure I'm happy with it
Thanks in advance.
Chris
Thanks in advance.
Chris
