Peachtree Nova vs rega brio R+dac with dynaudio x12
Mikejekel
i can get a secondhand peachtree Nova at a good price. I have been contemplating about changing the rega set for some time now. Even after replacing rx6 with dynaudio x12, I still feel there is brightness with lots of recordings. Even playing vinyl. Then there is the humming as well
Before jumping in the car for a two hour drive, would you guys think this is worth spending time on?
thanks
CnoEvil
556
14
I suppose it depends on what price you are paying for the Nova.
In your position, I think I would like to hear the Arcam A19 before committing.
radiorog
149
21
18,595
Possibly .....I wouldnt be able to put up with the humming. It is a fault and its a shame you didn't ask rega to fix it for you,like they did mine.
Mikejekel
Hi cno,
bidding starts at 550,- eur for the nova. I would definitely like to audition the a19 but it's 900,- eur and never see them on eBay.
Thanks for the advice
Mike
Happy_Listner
23
Keep in mind the Peachtree Nova does not have a phono stage like your Brio-R has. You will have to buy a separate phono pre-amp. Not sure if the Nova will give you that smooth sound you are looking for. It does have 1 tube that tailors the sound somewhat, but the amp section is class D. I never met a Class D amp that I liked very much. Many are too bright, or thin, with tonal colors being washed out. So at least get in a demo of the Nova before you buy it. I will say that the onboard DAC in the Nova is probably about as good as the Rega DAC is.
CnoEvil
556
14
Mikejekel said:
Hi cno,
Mike
Mike, just be careful that with factoring in fuel for the trip and the fact that bidding could push the price up, the A19 might not be a lot more (and I suspect more what you are looking for).
Hi-FiOutlaw
236
I had a system just like your for over a year, and i've always found hard to replace my speakers cables.
I had that system with Supra Classic 2x4mm cooper with a tin cover, but did demo almost all QED speaker cable range range, Van Den Hul and Kimber, to end up with a brand witch I knew nothing about, In-akustik.
Dynaudio X12 and the Rega Brio R are very sensible regarding cable match, i found that myself the hard way!
