John Duncan said:
oldric_naubhoff said:
John Duncan said:
So what do those graphs add to our knowledge of passive and active speakers? I'm too lazy to work it out and I know how you like this stuff.
maybe; a good speaker is one that measures well. and not if it's active or passive.
Do those graphs bear that out? Can you tell me where and how if they do?
all I can do is tell how to interpret the graphs. I'll leave the analysis for you to do.
first set of graphs (the colorful one) represents frequency response (black line high above) versus harmonic distortion component of the speaker in question. having ruler flat freq response is important because you want the speaker to follow the input signal as faithfully as possible. if the speaker don't play certain frequencies as loud as they should be played it's no good (that includes too quiet - freq dip - is no good and too loud - freq lift - is no good as well). however, I think that even more important feature of every speaker is how they cope with harmonic distortion. the lower the better, because you only want to hear the frequencies that are there in the original signal, not those created in addition by the speaker. I'd say -50dB below original signal for harmonic distortion is very respectful for a speaker. (but then there are ESLs which easily reach -70dB for 2nd harmonic). so basically, what to look for in those graphs is the bigger difference between black line and colorful ones the better. this indicates good quality drivers used.
the second set of graphs is so called "step response". this is the one which looks like EKG. this graph shows time coherence of the speaker. text book graph should look like a right triangle with bent long/right arm. (single driver speaker come closer to this theoretical ideal than others). you see overshot in most of the graphs. it means the tweeter leads the signal and then in hands down to midwoofer and woofer (in case of 3-way speaker). where you have a "lazy" bump behind the rapid rise it means you're most likely dealing with a 3-way speaker. you want a clean line in this graph. any irregularities indicate poorly damped/ designed drivers because they don't stop on the proverbial "dime" but continue vibrating and making sounds they shouldn't to. as you look at the graphs you realise that some speakers are more time coherent and some not so much.
the third set of graphs, the busy one, is so called "waterfall plot", due to its graphic representation. what is shows is how fast the drivers settle. the faster the better, of course. the ideal graph should look like a vertical wall, with no ridges (which indicate resonances) and bumps (which indicate slow decay of the driver). in this graph what happens say above 1000Hz is most important.
everybody wants a speaker with flat freq response, low distortion, fast decay and time coherent. but if I were to sacrifice one characteristic so I could have the other perfect it would be the freq response. your room will wreck even the flattest response. and with low harmonic distortion, perfect step response and vertical waterfall plot you'll know that you have extremely clean sounding speaker that images perfectly to boot.
that's in a nutshell. hope it helps.
