I ordered the PZ81 about a week ago from a local retailer,
and picked it up on Friday, complete with a stamped card for the free Panasonic
5 year warranty.
My first impressions were about the packaging, which merits
a mention as it’s quite impressive. Four plastic carry handles can be
unclipped, and the whole of the top of the box lifts off. The stand can then be
lifted out, the uprights screwed in, and the TV lowered on top. Nice bit of
thinking there from Panasonic.
The second impression was the physical appearance; sleek
& subtle and pretty good build quality (no sign of the overlong/over
tightened screws issue that some people have noted). The buttons on the remote
feel a little cheap, but otherwise it’s a pretty positive result.
I ordered the PZ81 on the back of spending quite a bit of
time testing the PZ85, and because reviews indicated the 81 was basically the
same plus Freesat. Unfortunately, there is one layout change that’s really bad
- on the PZ85, the third HDMI, and composite/SVIDEO connectors are on the rear
of the TV (near the side). On the PZ81, they’re under a flap on the front of
the TV, which really annoys me. Unless you want to plug something in temporarily,
these connectors are rendered useless, as you’d have ugly cables hanging from
the front of the TV. It’s a major design flaw IMHO, and a big step back from
the PZ85.
Onto use…
Scanning for analogue and Freeview channels was easy and
quick (I don’t have a dish yet for Freesat). Fan noise is pretty low, and is
only noticeable with the sound muted.
Analogue TV pictures are pretty ropey, but then it’ll never
get used that way.
Freeview pictures are a big disappointment. I know it’s said
that flat panels don’t do SD as well as CRTs, but I was hoping it would get a
little closer to my geriatric 32” Sony. Initially, it reminded me of old NTSC video -
overblown skin tones, soft fuzzy pictures... and with the added unpleasantness
of MPEG artefacts.
After a bit of playing with the settings, and running a THX
optimiser DVD, the picture is a bit better, but it’s hard to get natural skin
tones without the rest of the picture looking washed out. Motion is OK, but the
image is still soft and muddy.
Some broadcasts don’t look too bad (Wimbledon
coverage) but everything looks very flat and lacking in depth. I’ve seen CRTs
that looked much more ‘real’ than my Sony, but the plasma is way behind either.
DVD pictures over SCART are OK, but definitely not as good
as the CRT. However, my player (an ageing Denon DVD-A11) has a DVI-D output, so
I’m planning on getting a DVI to HDMI cable in the hope that the Denon’s own
upscaling will do a better job than the TV.
Freeview pictures over SCART from my Topfield PVR are pretty
close to the built in picture, if showing a few more artifacts (the internal tuner’s
electronics presumably processing the Freeview MPEG steams a little better for
the display).
A PS2 over component looks OK, though for some reason, my
PS2 RGB SCART cable results in a green image. This SCART lead worked fine on
the Sony, so anyone that’s got any ideas what’s wrong, please shout!
I bought the flat screen due to re-laying out my living
room, which meant the CRT was now too deep to be used. If you’re mainly going
to be watching broadcast SD, and don’t need the shallow depth of a flat panel,
my advice would be to stick with a CRT, until HD broadcasts become much more
widespread.
Over the next couple of weeks, I hope to set up a PC to play
Bluray discs, and to get a dish installed for Freesat. Given the positive
reception for the Panasonic plasmas, I’m confident it should look good for HD,
but at the moment it’s certainly not able to show its talents.
5 year warranty.
the PZ85.
Onto use…
get used that way.
of MPEG artefacts.
the display).
widespread.
