micks_address
- Aug 31, 2010
- 159
- 0
- 0
Hi strapped do you have the v20 wall mounted? I have my vt20 on a mount and at first drove me crazy but I added some rubber bushions between the bracket and tv and it helped quite a bit.
strapped for cash said:It was on the pedastal stand, where my G10 is sitting again. Unfortunately, the wall mount solution doesn't apply in my case.
Having switched back, I miss the detail, accurate colours and darker blacks of the V20; but importantly the G10 isn't so noisy it interferes with viewing, while 100Hz scanning looks silky smooth by comaprison. If only you could combine the best of both sets that would be a fantastic TV. Maybe, just maybe, that'll be the G30, though I feel less confident they've sorted the motion issue.
Perhaps my V20 was more prone to buzzing than others, but I don't want the aggravation of swapping TVs on the off chance I'll get one I'm happy with. I think the sensible thing is to sit back and see what happens with 2011 models from all manufacturers.
Glad you're happy with the VT20, though. I can genuinely understand why anyone that isn't irritated by buzzing, or landed a 2010 Pana television that buzzes less than the one I'm returning, would be very happy.
Thegelman said:Not sure how Amazon are though with problems.
good spot gel, that is a great price. trouble is the g series are prone to the same issues that afflict the v series, maybe that's why it's so cheap 🙂Thegelman said:Just seen this, less buzzing and if you don't put any firmware updates on (if it was me) then seems not bad:
http://www.amazon.co.uk/gp/product/B0039SLYGE/ref=s9_simh_gw_p23_d0_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-2&pf_rd_r=1MMS7GBCRAFDTA1JD22Q&pf_rd_t=101&pf_rd_p=467128533&pf_rd_i=468294
