Pace vs Samsung Sky HD Box
trevoralves:Which Sky HD box would you recommend?
I've got the new Samsung which is exactly the same spec (no component but coaxial as well as optical) as the Pace. I have no idea if they are any different but so far so good for me (it only arrived on Friday).
AFAIK Sky do not actually give you a choice in which HD box they give you as it is normally a case of what ever box the engineer happens to have on his van.
Gerrardasnails:trevoralves:Which Sky HD box would you recommend?
I've got the new Samsung which is exactly the same spec (no component but coaxial as well as optical) as the Pace. I have no idea if they are any different but so far so good for me (it only arrived on Friday).i doubt if there's any difference tbh, as there built under license from sky, who specify there requirements, component quality etc
