Ortofon om 10-20-30-40 ....
Montecristo
Hi to Everyone , i have been offered an Ortofon , NIB, LM 30 stylus , and i have been told i can put it in any om body , because they are all the Same ....is that true ?
Yes, if you have an OM cartridge then the various styli will fit it as they are just different shapes of diamond.
The LM30 is almost the most expensive of the line because it uses Nude Fine Line stylus.
The LM40 is the dearest using a Nude VDH stylus.
regardless if the LM 30 or whatever would fit , my main question is if the cartridge itself is the same for the om10-20-30-40 ...
