- Jul 4, 2011
- 20
- 0
- 0
Well, no, to clarify, there's not "a problem with tx range". In fact, it looks like there's a potential problem with some specific units of some of Onkyo's range (i.e. those manufactured between November 2011 and January 2012).Given it states "In individual cases disturbances may occur, for example, the product switching itself off", this suggests if you're not getting any issues, you don't need to worry. However, to be absolutely sure, Onkyo have provided the facility to input your model and serial number so you can check all is well.bearwolfblade said:Seems there's is a problem with tx range http://www.uk.onkyo.com/en/product-recall-80305.html
talk about being pedantic most of the models are from the tx range or did you not bother to check as usualprofessorhat said:Well, no, to clarify, there's not "a problem with tx range". In fact, it looks like there's a potential problem with some specific units of some of Onkyo's range (i.e. those manufactured between November 2011 and January 2012).Given it states "In individual cases disturbances may occur, for example, the product switching itself off", this suggests if you're not getting any issues, you don't need to worry. However, to be absolutely sure, Onkyo have provided the facility to input your model and serial number so you can check all is well.bearwolfblade said:Seems there's is a problem with tx range http://www.uk.onkyo.com/en/product-recall-80305.html
Not at all. In fact the reason I was able to give accurate information (instead of generalisations) was because I did check. However, there are also models of the TX range which don't have the issue.bearwolfblade said:talk about being pedantic most of the models are from the tx range or did you not bother to check as usual
how many sane people would actually know if there tx–$&$& was actually made within the specified time period or if they bought new old stock. Without checking on the onkyo site your tx-$&$& could develop the fault its been recalled for. most of the recalled models have the prefix tx if you go to the onkyo site you can then find out if your model is at risk . I didnt say every tx was faulty and included the link so people could check first. Even then at the onkyo site they can only tell you if there may be a risk to your unit which is why you can email your model and serial number to onkyo for helpprofessorhat said:Not at all. In fact the reason I was able to give accurate information (instead of generalisations) was because I did check. However, there are also models of the TX range which don't have the issue.bearwolfblade said:talk about being pedantic most of the models are from the tx range or did you not bother to check as usual
Not at all - there are also a number of newer models from the TX range which don't have the issue, so to insinuate it was an issue with the TX range was inaccurate. Ironically, the reason I was able to give this accurate information (instead of sweeping generalisations) was because I did check. As usual 🙂
bearwolfblade said:how many sane people would actually know if there tx–$&$& was actually made within the specified time period or if they bought new old stock.
seems there was a problem being unable to edit my first post which led to this thread .i purchased the tx-8050 in november so could be a unlucky one. until i pull the unit out and check the serial no. I dont know even if mine is faulty yet and yes it did feel like you were having a dig at me and my misfortunes .thinking about it a man of your calibre would never lower yourself to those standardsprofessorhat said:bearwolfblade said:how many sane people would actually know if there tx–$&$& was actually made within the specified time period or if they bought new old stock.
I'd say any sane person who bought their Onkyo prior to November 2011 could be extremely confident it wouldn't develop this fault. 100% confident in fact 😉 I for example own an older Onkyo TX AV receiver - from your post, it looked like mine might possibly have an issue. As I discovered though, since it was definitely manufactured prior to November 2011, I can be 100% sure it doesn't.
At any rate, I didn't post my reply to annoy or antagonise you, just to present more facts so that people didn't have to worry about it and click the link to discover this.
bearwolfblade said:thinking about it a man of your calibre would never lower yourself to those standards
Andy Clough said:Just to clarify, I spoke to Onkyo UK's PR man yesterday and they reckon the number of UK-specific products affected is fairly small. As professorhat has already pointed out, you can check your serial number on the Onkyo website to see if it may need fixing. Full details in our news story.
and theres me thinking you was the profs alter ego :rofl:The_Lhc said:bearwolfblade said:thinking about it a man of your calibre would never lower yourself to those standards
Too right, it's not like he's me or anything...
bearwolfblade said:and theres me thinking you was the profs alter ego...
chebby said:bearwolfblade said:and theres me thinking you was the profs alter ego...
Don't give him another one.
professorhat said:chebby said:bearwolfblade said:and theres me thinking you was the profs alter ego...
Too true, I can barely fit in my living room as it is...
chebby said:professorhat said:chebby said:bearwolfblade said:and theres me thinking you was the profs alter ego...
Actually I was writing about The_Lhc.
