Old Cyrus Gear
Can anyone tell me any more about these products.
Cyrus III Intergrated amp
Cyrus DVD7 CD/DVD
How old are both these units? Sound Quality compared to the latest cyrus products? Would they pair well? Improvement on my current set up Arcam avr250 Arcam dv79
Only playing stereo music and dvds. Teamed with monitor audio rs6's
I gave my view on your other thread but just to add...
Unfortunately, just because a product gets 5 stars, doesn't mean it will work in any given situation....synergy and balance are always vital.
It is also crucial to understand how you like your music presented, and ignoring this leads to dissatisfaction. The fact that you went for Arcam and mostly enjoy the way it sounds, gives a guide as to where you should look eg. (Arcam), Leema, Musical Fidelity, Electrocompaniet, Peachtree etc.
I think I've probably said enough at this stage, so good luck with your choices
Cno
Cyrus DVD7 CD/DVD
Cyrus and RS6s? a definite 'no no'.
Don't look at brands that won't appeal. Cyrus is good if you like a 'in ya face' presentation. Clearly as Arcam tick most of your sonic boxes, Cyrus is the Polar opposite.
As Cno says you could maximise your Arcams. Perhaps if the receiver has the connections just add a DIVA A65+. That'll give you the best of both worlds.
Current Cyrus wouldn't be an issue as it's a little warmer than it used to be. The older stuff did have a tendency towards brightness because of their lean nature, so I wouldn't recommend them to go with RS6's. Your Arcam would be a better match.
Cyrus DVD7 CD/DVD
Hi dean111music
If you're happy with the system then i'll recommend that you carry on using it and save your money.
All the best
Rick @ Musicraft
