- Aug 10, 2019
- 2,556
- 5
- 0
Hi Guys,
Taken delivery of a HK AVR 255 Amp today which is rated at 8 ohm.
Am having 5 Scandyna micropod speakers rated at 4 ohm delivered tommorow and have only just realised the mismatch...
however looking at HK's site I found an FAQ as follows -
Can my surround-sound receiver handle a 4-ohm load?
All
Harman Kardon Audio/Video receivers can handle most 4 and 6 ohm
speakers on the market today. However, there are some manufacturers'
speakers that have a minimum impedance well below the 4 and 6 ohm
nominal impedance. In this situation, the receiver will protect itself
by going into standby mode. This will not damage the speakers or the
electronics, but it is an indication that the speaker in question is
not compatible with our receiver. Note: The continued use of the
receiver with speakers that cause it to shut down can result in
eventual failure of the receiver which is not covered by the warranty.
So does this mean it's all okay? the micropods are rated 86db spl (1w @ 1m) 4 ohm. compatible with amps from 10w - 100w
Thanks for your help!
Nick
All
Nick
