Oh dear. A cd is jammed in...
floyd droid
39
Play a record ;).
If as suggested above dosnt work it looks like a bit of dismantling is on the cards.
chebby
1,251
24
19,195
Power off/power on. Try opening drawer again.
Power off then unscrew cover and eyeball the situation. See if there's a big clump of 'Axminster' covering a sensor or anything else thats obvious and easy to deal with.
Crocodile
38
As above, with the power off the draw mechanism should be free to be opened manually. Just don't force anything.
If the disc is skewed or the clamp is partially down preventing this then you'll have to remove the case.
drummerman
540
I have heard she likes her privacy ...
... perhaps you could lure her out with gently waving a Peter gabriel CD in front of the player
regards
Sospri
28
plastic penguin
regards
Another little secret, DM...;)
Yes unplugged it (CDP that is) and prised open the drawer.
Think I may to get it serviced.
shafesk
136
The player doesn't like Kate Bush and I think its acting out! Well happened with my samsung dvd player. I just opened the case and it was a simple matter to release it from inside. You can do it plasticpenguin, cause I have the motor skills of a 6 year old.
Best of Luck,
Shafin
