Normal wiring and bi-wiring
normal wiring is a single run of speaker cable between the amp and speakers. if you have biwirable speakers you use either 2 runs of single cable or bi-wire cable that has 4 conductors. you take the links(jumpers) out between the top and bottom posts on the speakers you then connect one pair of cable's/conductors to the top set of (hf) binding posts and the other pair to the bottom set of (lf) binding posts.
which is better is a contentious issue. do a search of the forums to see what i mean. suggest you try it for your self to see which you prefer
