Fist impression
Clear midrange, good bass, the highs are not to loud intrusive (good for rock), no unsually noise, with my reloop i lowered the arm at it went down fast and skipped a little, rega intro smooth as butter
(sooo nice)
Doesn't look like a million and looks stupid since i had to put something under the right front feet (white), speed isn't 100% stable,heavy phone on a light platter? (android speed app, nothing noticeable when listening to music, mabye i need to upgrade the belt ?)
Pros: sound, price,butter smooth arm when i lower it, silent, simple look,easy to set up (counter weight all the in it's within the 2 and 3gram recommended tracking force (between 2.5 and 2.7 gram), easy to upgrade stylus
Cons: doesn't look like a million,speed isn't 100% stable with android app (phone on the platter), looks stupid when i had to put someting under the right foot to balance,level it (white,not a fault,con by rega), light platter, might not have the most detailed sound
You can get a 30-40 year rega planar 3 used for 200 euros or a new rega planer intro for the same price with warrenty and you know it hasn't been used for 30-40 year.
I only have 33.33 rpm records so i didn't list the manual speed (change positioning of the belt) as a con, since i don't use it.
It doesn't try to be something it isn't, it's just a good sounding turntable for not alot of money
Music used: Tracy Chapman Tracy Chapman (a few songs) Focus At the rainbow (both sides)
Update RPM Speed & woow for android and my phone on top of my nobsound record weight (under 200gr) speed 33.21rpm, stable speed,low woow is better than 33.33 rpm and high woow
Upgrade? which one (i so the video the whole time without sound listening to a record)
View: https://www.youtube.com/watch?v=0aZJnEje6RI
What i notice most is that the rega intro compared to my reloop (a little heavier and dd) has a more lively sound
