New to Vinyl, Best Budget Turntable?
Al ears said:
DIB said:
Nikphillips said:
It may be worth scouring auction sites and the classifieds for a Systemdek. Any model would do. They seem to go for a lot less than they are worth. I see them regularly go for less than £100. It's a cracking deck. Suspended sub chassis. Easy to adjust and set up.
Good luck. Hope you get sorted.
As a former Systemdek iix owner I would agree about their quality. However they are very bouncy decks and I would say a dedicated wall shelf is essential.
Funny that as I've found it's the ones that do not bounce that require a wall shelf.
Having said that I guess ideally all such sources would benefit from isolation of this type.
Maybe it was the stand that I had at the time, floorboards etc. but with my Systemdek I found that I had to tread very carefully anywhere near to it, otherwise the stylus had a habit of jumping out of the grooves. A wall shelf sorted that particular problem.
A fine deck nonetheless.
